l27
Dec 13, 2016Guide
Mirror uplink on a stack
I have enabled OSPF across a connection coming in and I want to split that connection and plug it in to both switches. Is this possible? I cannot add the same IP address to a port on the other sw...
l27
Dec 23, 2016Guide
Sorry I haven't had allot of time to look at this. From the Netgear perspective how would I do this because I cannot figure out how to assign the same ip address to both ports.
I probably won't have time to look at this for a week or so. Thanks for helping me with this.
- Retired_MemberDec 26, 2016
Hi l27,
As your reqirement, you could configure as below:
Step1: add two ports to one LAG port; refer to the link (Page258 Link Aggregation Groups).
Step2: create a VLAN, add the LAG port to VLAN; refer to the link (Page169-175 Configure VLANs).
Step3: enable L3 VLAN routing port and set IP address; refer to the link (Page315 Configure VLAN Routing).
Regards
Ericz
Netgear Employee
- l27Dec 28, 2016Guide
That makes perfect sense. I will give that a shot. Because of the nature of these changes I will not be able to do this without scheduling maintenance downtime. So please be patient if I don't reply within the next week or 2.
Thanks,
John
