l27
Dec 13, 2016Guide
Mirror uplink on a stack
I have enabled OSPF across a connection coming in and I want to split that connection and plug it in to both switches. Is this possible? I cannot add the same IP address to a port on the other sw...
l27
Dec 23, 2016Guide
Sorry I haven't had allot of time to look at this. From the Netgear perspective how would I do this because I cannot figure out how to assign the same ip address to both ports.
I probably won't have time to look at this for a week or so. Thanks for helping me with this.
Retired_Member
Dec 25, 2016Hi l27,
As your reqirement, you could configure as below:
Step1: add two ports to one LAG port; refer to the link (Page258 Link Aggregation Groups).
Step2: create a VLAN, add the LAG port to VLAN; refer to the link (Page169-175 Configure VLANs).
Step3: enable L3 VLAN routing port and set IP address; refer to the link (Page315 Configure VLAN Routing).
Regards
Ericz
Netgear Employee
- l27Dec 28, 2016Guide
That makes perfect sense. I will give that a shot. Because of the nature of these changes I will not be able to do this without scheduling maintenance downtime. So please be patient if I don't reply within the next week or 2.
Thanks,
John
- DaneAJan 19, 2017NETGEAR Employee Retired
l27,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- l27Jan 21, 2017Guide
Thanks for following up. I just got some time to try this finally. I couldn't get it to work. As soon as I disabled OSPF on port 1/0/2 it seams like all routing would stop. I did create the LAG and the VLAN, added the IP address and enabled OSPF for the new VLAN but it wouldn't work. I have a local VLAN that would stop working. Oddly enough I could ping a device on the other local VLAN from the other VLAN. So from VLAN 1 to VLAN 100 I could ping but nothing else would work. Very strange. Also routes to the other site would not work across the newly created VLAN 10. Also after I removed the port from OSPF and enabled OSPF on the new VLAN I could ping the VLAN ip address from VLAN 1 but I would have random time outs.
Not sure where to go from here.
