MirrorIsland's avatar
MirrorIsland
Follower
Feb 09, 2017
monitoring frames/packets on Netgear Prosafe GS748T
We have
3 x Netgear Prosafe GS748T – 3H31417C003FE / 3H31417L00392 / 3H31417F00339
We are experiencing high TCP latency within our infrastructure which predominantly is a RDS/Terminal Services environment.
I was wondering if I might ask the best tools, or if they are tools by HP that can monitor and detect network related clashes on switch ports.
Many Thanks,
Shawn McKendrick
1 Reply
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi MirrorIsland,
    Welcome to Netgear Community!
    If you want to monitor packages on switch port you can use the funtion of mirroring to copy package form a port to anothe port that conncted with a pc.
    On pc use wireshark to view these copied packages.
    About how to config mirroring on siwtch you can refer to here page 53
    And wireshark  can be downloaded at here
    Regards
    Carl
    Netgear Employee
ProSupport for Business
