pieterjanheyse's avatar
Jan 31, 2019
Monitoring the interlinks on a M4300 stack through SNMP
I'd really like to be able to monitor the links between 5 M4300 switches in a stack through SNMP. When I monitor the ports that are used for stacking, the counters all give me 0 as output, not the traffic volume I am expecting. This is probably due to the fact that those ports are in stack mode, not 'normal' ethernet mode. Are there other counters I can use, to monitor those ports or can anyone give me some advice here?
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi pieterjanheyse,
    It seems that you are not getting any data from your stack. May I know what is the monitoring tool that you are using? What is the OID that you used?
ProSupport for Business
