sspeed22
Jul 23, 2019Aspirant
MS510TX IC Temp(C)
Can anyone with a MS510TX take a look at the IC Temp(C) value on their front page and tell me what they have? I've had a couple issues lately where the switch seems to have rebooted. The room is...
schumaku
Jul 23, 2019Guru - Experienced User
Enable buffered and Flash log in case these are not. If you have a 24*7 system like a NAS around, set up a syslog server and point the switch to that device. This should catch odd things, and show traces of a crash and reboot - if any.
Chip temperatures around 55...65°C, at around 23..25°C environment (MS510TX, no PoE inside). Depends on the activity, especially on the 10G and MultiGig ports. No adhere effects here.
Not sure on how these higher temperatures affect the durability or long term reliability, but at least one MS510TX here is back from the Beta test days, still performing nice (aside of a small hardware flaw which was ironed on the mass production).
sspeed22
Jul 24, 2019Aspirant
Thank you, this is one of the beta units. What was the hardware flaw on the betas?
