Test15's avatar
Test15
Follower
Apr 17, 2025
MSM4352 - Inquiring about why the MSM4352 does not include external PSUs in the packaging to support
The customer contacted NETGEAR support to clarify the power requirements of the NETGEAR M4350-44M4X4V switch. The customer expressed significant dissatisfaction and perceived inaccuracies in the prod...
  • LaurentMa's avatar
    Apr 18, 2025
    Hi Test15 ,
    Thank you for your message. For PoE++ (90W/port) managed switches supporting large PoE budgets without any additional PSUs, please check the M4250 series (www.netgear.com/m4250) as there are 12-, 24-, and 40-port switches with multiple internal power supplies ready to go.
    I appreciate your feedback on M4350 and trust that our product pages and our datasheet are clearly describing the M4350-44M4X4V (MSM4352) capabilities:
    - Product Page:
    https://www.netgear.com/business/wired/switches/fully-managed/msm4352/
    M4350-44M4X4V Fully Managed Switch (MSM4352)
    44x2.5G, 4x10G/Multi-gig PoE++ (194W base, up to 3,314W) and 4xSFP28 25G (MSM4352) Managed Switch
    • 44 2.5G and 4 10G/Multi-gig PoE++ ports with 4 25GBASE-X SFP28 uplinks
    • 550W internal power supply providing 194W of PoE budget
    • 2 slots for modular power supplies (1+1 redundancy and/or EPS share)
    • Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
    • The PoE budget can reach 3,314W, the redundant PoE budget can reach 1,794W
    - M4350 Datasheet:
    https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf?_ga=2.67447889.1700412158.1744896911-33583629.1734436711
    Everywhere the M4350-44M4X4V (MSM4352) shows with 194W base PoE budget and max 3,314W when additional PSUs.
    Simple table can be found on page 5, with the various combinations of PSUs.
    May your message and my message serve the rest of the Community! Have a great day, Laurent
ProSupport for Business
