jjones2017
Oct 04, 2017Follower
Multi-Gig What management/operations/industry standard protocols does it interact with?
Additionally, Is it capable of integrating with existing authentication databases via protocols such as the Terminal Access Controller Access-Control System (TACACS) or Remote Authentication Dial-In ...
LaurentMa
Oct 04, 2017NETGEAR Expert
Thanks for your question.
Both Smart Managed Plus and Smart Managed Pro switches offer intuitive Web user interface for configuration and management. The Smart Managed Pro switches comply with SNMP-read requirements and Syslog remote logging.
Fully Managed Switches (the Multi-Gigabit version is called M4200) offer the same Web user interface and Syslog capability, but also come with industry-standard Command Line Interface (CLI) accessible from local console port (RJ45 serial or mini-USB), remote Telnet or SSH. Only the Fully Managed switches will be used with typical Radius User Management for multiple admins login/capabilities and TACACs automatization. SNMP-read and SNMP-write are supported across the board. We don't support JSON-RPC API nor NETCONF.
I hope this helps!
