mayank7489
Nov 02, 2017Aspirant
Multicast stops working after about 20 minutes
Hello Everyone... We have the following setup.. 1 x XSM7224S-100AJS (M7300) running 9.0.1.42 acting as a Core 2 x M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ acting...
- Nov 28, 2017
Hi Hopchen,
Apologies for the late reply...
Bascially this is the update...
Did everything recommended except the below item 3 as this option was not in my Core..
3. Allow querier mode each VLAN.
Switching > Multicast > IGMP Snooping > IGMP VLAN Configuration > Enable Proxy Querier mode for you VLANs here and click Apply.The site just confirmed that multicast is working fine now... :)
One thing I should mention that when I changed the multicast protocol, my remote connection dropped out for about 30 seconds... But then it came good.
Thanks you very much for your help on this...
Mayank
DaneA
Nov 15, 2017NETGEAR Employee Retired
Hi mayank7489,
I can confirm that the download link posted by Hopchen is working and I was able to download the files.
Kindly click on the attachment (the paper clip icon at the right side of this post) to download the file. It is the same files that Hopchen posted for you and I just saved it as .pdf format so that I could attach it here..
DaneA
NETGEAR Community Team
Hopchen
Nov 16, 2017Prodigy
Thanks DaneA
mayank7489 - I have also create a Google Drive link (below) in case you want the original docs instead
https://drive.google.com/file/d/1VhxH60gsOrIbirbkCewi68R_kiYI6DgL
Cheers
- mayank7489Nov 16, 2017Aspirant
Hi Hopchen,
I managed to download the documents via Google drive link. Thanks..
Let me digest them..
- HopchenNov 17, 2017Prodigy
No problem mayank7489
Take your time. Please remember that these docs are just some guidelines on how to set it up correctly. It won't necessarily solve your issues straight away, but at least we will have a good base to work and troubleshoot from.
Cheers
- mayank7489Nov 19, 2017Aspirant
Nice documents & really well written.. Have gone through them...
So in my case under Core > Routing > Multicast, DVMRP is enabled and assigned to 2 Vlans. Hence all I would need to do is to Disable DVMRP & enable PIM-DM and assign it to the 2 Vlans. This will move the Layer 3 Multicasting protocol for the Core from DVMRP ti PIM -DM.
As for the IGMP Snooping, I noticed is that "Querier IP address" (this is the only place it is configured) under Core > Switching > IGMP Snooping > Querier Configuration is set to a IP address 172.16.210.17 which is a IP address within a configured VLAN. From what I understand this IP address is not an actual IP address and can be anything. e.g. 1.1.1.1. Would this be causing any issue for me and would it be better for me to specify it to be a arbitary IP address like 1.1.1.1?
