mayank7489
Nov 02, 2017Aspirant
Multicast stops working after about 20 minutes
Hello Everyone... We have the following setup.. 1 x XSM7224S-100AJS (M7300) running 9.0.1.42 acting as a Core 2 x M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ acting...
- Nov 28, 2017
Hi Hopchen,
Apologies for the late reply...
Bascially this is the update...
Did everything recommended except the below item 3 as this option was not in my Core..
3. Allow querier mode each VLAN.
Switching > Multicast > IGMP Snooping > IGMP VLAN Configuration > Enable Proxy Querier mode for you VLANs here and click Apply.The site just confirmed that multicast is working fine now... :)
One thing I should mention that when I changed the multicast protocol, my remote connection dropped out for about 30 seconds... But then it came good.
Thanks you very much for your help on this...
Mayank
Hopchen
Nov 16, 2017Prodigy
Thanks DaneA
mayank7489 - I have also create a Google Drive link (below) in case you want the original docs instead
https://drive.google.com/file/d/1VhxH60gsOrIbirbkCewi68R_kiYI6DgL
Cheers
mayank7489
Nov 16, 2017Aspirant
Hi Hopchen,
I managed to download the documents via Google drive link. Thanks..
Let me digest them..
- HopchenNov 17, 2017Prodigy
No problem mayank7489
Take your time. Please remember that these docs are just some guidelines on how to set it up correctly. It won't necessarily solve your issues straight away, but at least we will have a good base to work and troubleshoot from.
Cheers
- mayank7489Nov 19, 2017Aspirant
Nice documents & really well written.. Have gone through them...
So in my case under Core > Routing > Multicast, DVMRP is enabled and assigned to 2 Vlans. Hence all I would need to do is to Disable DVMRP & enable PIM-DM and assign it to the 2 Vlans. This will move the Layer 3 Multicasting protocol for the Core from DVMRP ti PIM -DM.
As for the IGMP Snooping, I noticed is that "Querier IP address" (this is the only place it is configured) under Core > Switching > IGMP Snooping > Querier Configuration is set to a IP address 172.16.210.17 which is a IP address within a configured VLAN. From what I understand this IP address is not an actual IP address and can be anything. e.g. 1.1.1.1. Would this be causing any issue for me and would it be better for me to specify it to be a arbitary IP address like 1.1.1.1?
- HopchenNov 20, 2017Prodigy
Hi again,
Yes, you simply turn off DVMRP and enable PIM-DM instead. I think PIM-DM is a much better solution for a network your size (based on the topology you gave). It is simpler and it "just works". It has some downsides, but you won't notice those unless you get more routing hops. At that point you would start looking into PIM-SM. But for now, PIM-DM is good.
To enable PIM-DM, you need to:
1. Enable mcst routing, globally.
System > Routing > Multicast > Global Configuration > Enable Admin mode here and click Apply.2. Enable IGMP routing globally.
System > Routing > Multicast > IGMP > Global Configuration > Enable Admin mode here and click Apply.3. Enable IGMP routing on each VLAN.
System > Routing > Multicast > IGMP > Routing Interface Configuration > Enable Admin mode on your VLANs here, and click Apply.4. Enable PIM-DM globally.
System > Routing > Multicast > PIM > Global Configuration > Enable PIM-DM mode here and click Apply.5. Enable PIM routing on each VLAN.
System > Routing > Multicast > PIM > Interface Configuration > Enable Admin mode on your VLANs here, and click Apply.
As for the IGMP snooping. I would encourage you to do snooping per VLAN. Reason being that it gives you more control. Say, I want to do snooping for two VLANs, but not a 3rd VLAN. So, my suggestion is the guide was do to snooping and querier, per VLAN. You can do it as follows:1. Enable IGMP snooping globally.
Switching > Multicast > IGMP Snooping > Configuration > Enable Admin mode here and click Apply.2. Enable IGMP snooping on your VLANs.
Switching > Multicast > IGMP Snooping > IGMP VLAN Configuration > Enable Admin mode for you VLANs here and click Apply.3. Allow querier mode each VLAN.
Switching > Multicast > IGMP Snooping > IGMP VLAN Configuration > Enable Proxy Querier mode for you VLANs here and click Apply.4. Enable IGMP querier globally.
Switching > Multicast > IGMP Snooping > Querier Configuration > Enable Querier Admin mode here and click Apply. Leave the IP at 0.0.0.0 in this section.5. Enable IGMP querier on your VLANs.
Switching > Multicast > IGMP Snooping > Querier VLAN Configuration > Type in VLAN ID, for the VLAN you want to enable querier mode for. Also, enable "Querier Election Participate Mode" and specity the querier IP address. Hereafter, click Add.As for the querier IP address. You are correct that the IP you specify here, is just an arbitrary IP. It is solely used for an election model. The VLAN Querier with the lowest IP value, will be the querier for that VLAN. I would using something like this:
- Core switch VLAN 10 querier IP: 1.1.1.10
- Core switch VLAN 20 querier IP: 1.1.1.20
- Destibution switch VLAN 10 querier IP: 2.2.2.10
- Distribution switch VLAN 20 querier IP: 2.2.2.20
- etc.
This way I create an election system where my core is main querier and my distribution switch will take over, in case the core experiences issues within one or several VLANs. I hope that makes sense?
The reason you see 172.16.210.17 is likely just because the switch chooses the same IP as it's own management IP interface (per default). But, you want to select the IP value yourself, based on a hierarchy system that you create - i.e. my core is the main querier, then my distribution, etc.
Any questions - let me know.
Cheers - mayank7489Nov 28, 2017Aspirant
Hi Hopchen,
Mayank
- HopchenDec 01, 2017ProdigyHi again.
No problem at all. Glad it's better now :)
Yea, don't worry about the proxy setting for IGMP Snooping. On some newer switches you need to set it up in order to allow IGMP Querier on that given VLAN. If you don't see that option, don't worry.
If you encounter any issues, do give us a shout. Best of luck!!
