jdunlap
Feb 07, 2019Follower
Need Help Selecting Correct IGMP Switch
I need help selecting the correct switch for a particular application here at work. We need to have 2 switches connected together via fiber and have at least 16 ports. They need IGMP and I guess one ...
- Feb 08, 2019
Hi jdunlap,
Welcome to our community and Thank you for choosing NETGEAR! :)
It seems that you are looking for a 16-port switch that supports IGMP. Most of our switch supports IGMP except the pass thru devices. You may check the XS716T as it also supports 10G.
Here is our switch selector.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Feb 08, 2019NETGEAR Employee Retired
Hi jdunlap,
