vortexqc
Aug 11, 2019Aspirant
need to connect GSM7248V2 and a GS728TPP switch with a SFP CABLE
what product number should i ordered to NETGEAR to connect those 2 switch with a SFP or SFP+ Cable to link them up i need those 24 port on the GS728TPP for ip phone so i must use a fiber cable to...
DaneA
Aug 12, 2019NETGEAR Employee Retired
The SFP modules that are compatible to both GSM7248V2 and a GS728TPP are the AGM731F and AGM732F. As reference, kindly check the last page of their respective data sheets below:
Kindly check below for more information about the AGM731F and AGM732F:
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
vortexqc
Aug 12, 2019Aspirant
AGM731F is SFP+ tranceiver but in the documentation those 2 unit are only SFP will it work with SFP+ tranceiver ?
