vortexqc
Aug 11, 2019Aspirant
need to connect GSM7248V2 and a GS728TPP switch with a SFP CABLE
what product number should i ordered to NETGEAR to connect those 2 switch with a SFP or SFP+ Cable to link them up i need those 24 port on the GS728TPP for ip phone so i must use a fiber cable to...
schumaku
Aug 12, 2019Guru - Experienced User
As both end SFP are plain SFP (no SFP+ on one end), you might have the possibility to deploy a simple an inexpensive SFP-DAC, like an AXC761 (1 m / three feet) or AXC763 (3 m/ ten feet).
Can DaneA validate this for thee two switch models/model lines please?
vortexqc
Aug 12, 2019Aspirant
AXC761 is SFP+ will it work ? the 2 switch are SFP not SFP+
- schumakuAug 13, 2019Guru - Experienced User
AGM731F is the NETGEAR ProSAFE 1000BASE-SX SFP GBIC Module - not requiring an SFP+ garage.
vortexqc wrote:AXC761 is SFP+ will it work ? the 2 switch are SFP not SFP+
AXC761 is like all shorter ones a passive DAC cable, which in general works to connect two SFP+ ports (as a 10G link) or two SFP ports (as a 1G link). Very often, a DAC works for for SFP+ to SFP connections (obvious again as a 1G link), too. I've challenged DaneA because the DAC is not on the compatibility list officially for these switches (the DAC were introduced later than the compatibility lists were published!) - we know that the Smart Managed Plus and Smart Managed Pro don't enforce exact vendor and models (e.g. XS7xxT [SFP+] <-> GSxxx or GCxxx [SFP] are working nicely - but the Netgear Managed switches might be different. Probably LaurentMa might shed some light here again, merci!
- LaurentMaAug 13, 2019NETGEAR Expert
Hi,
No, a 10G SFP+ DAC cable will NOT work when inserted into an 1G SFP port, it won't be recognized and there is no way to establish a link at 1Gbps using it.
Either the 1G SFP ports on both of your switches receive a 1G SFP transceiver such as our AGM731F, or a MSA-compliant 1G DAC cable. I don't think this is common, and you might have trouble finding any. I would rather insert a 1000BASE-T RJ45 SFP transceiver such as our AGM734 in both switches' SFP port, and use CAT5E or better cable between the two.
LaurentMa wrote:No, a 10G SFP+ DAC cable will NOT work when inserted into an 1G SFP port, it won't be recognized and there is no way to establish a link at 1Gbps using it.
Edit: Ignore m previous text, of course you are correct!
LaurentMa wrote:I would rather insert a 1000BASE-T RJ45 SFP transceiver such as our AGM734 in both switches' SFP port, and use CAT5E or better cable between the two.
Yes, for the 1G range the AGM734 are an affordable alternative to short range Multimode fiber modules, indeed.
