Gyuri85
Sep 11, 2012Aspirant
Netgear FSM7328S switch
Hi, There is a switch FSM7328S. The problem with that does not boot from the internal program (FirmWare). Can anyone help? In this case can be re-loaded on the FW? After switching on, the PWR LED ...
Gyuri85
Hi,
After a long trial the COM port responding. The following messages show:
U-Boot 0.3.0 (Jun 28 2006 - 13:12:54)
Board: Netgear FSM73xxS
DRAM: 128 MB
Flash: 16 MB
But does not boot on the switch.
It is likely that the switch is dead? Can not be recovered?
It's like you have received a "Format" command.
DRAM: 128 MB
Flash: 16 MB
