Bag59
Aug 26, 2022Aspirant
Netgear GS116Ev2 - Connectivity Issues
Have a network set up with GS308T's. Works great and using LAG with LACP. Wanted more ports so looked for a GS316T but no joy. They don't exists so found a GS116Ev2. Looked similar, had LAG as ...
Bag59
Aug 29, 2022Aspirant
Problem solved with Switch It just doesn't like two cables connected, ready to be turned into a LAG link, without a LAG configuration set up at both ends. Should have been obvious as that was the only non standard settings but I wasn't thinking straight after struggling with getting the IP set up.
