ithardware
Jun 16, 2023Aspirant
Netgear GS724TP
Hi all,
I have a Netgear GS724TP. I set it to factory default.
if I plug a computer it get an IP, but if I plug an IP phone it does nothing.
for some reason the IP phone is not connecting to the network. it keep saying Verify your network connection.
there's probably a setting on the Netgear that I have to set.
Wild guess VoIP VLAN is enabled, and throws the IP phone into this other VLAN (not configured probably)? Disable the VoIP VLAN.
- ithardwareAspirant
I didn't set any Vlan. everything is set to default. I don't see a Disable for the Vlan
This UI does not look like a GS724TP (dating from 2007) my friend. Probably more a GS724TPv2, the label might say something like GS724TP-200xxx?
