markii_0204
Jul 29, 2020Aspirant
netgear gs728tp vlan 1 not create by user
hello i want to create new vlan on netgear gs728tp but i cant untag or tag vlan 1 says "vlan 1 not create by user" , but i have a switch netgear gs724tp i can configure the vlan 1. so i try to set vl...
markii_0204
Jul 30, 2020Aspirant
Thanks for the reply.
This is the exact model of my switch : GS728TP — 28-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 4 SFP Ports (16 PoE, 8 PoE+) (192W)
Firmware Version 6.0.1.29
I want to achieve is to have internet access on both vlan i will create. eg vlan 20 and vlan 5 both have access to internet
but my problem is i cant untag the vlan 1 were the internet is connected. i have a GS724tv3 FW 5.4.2.18 , the configuration is like this.
THIS CONFIGURATION IS WORKING ON "GS724tv3 FW 5.4.2.18"
PVID PORT VLAN1 VLAN5 VLAN20 REMARKS
5 1 U U CAN ACCESS INTERNET
5 2 U U CAN ACCESS INTERNET
5 - U U CAN ACCESS INTERNET
20 19 U U CAN ACCESS INTERNET
20 20 U U CAN ACCESS INTERNET
20 21 U U CAN ACCESS INTERNET
20 22 U U CAN ACCESS INTERNET
20 23 U U CAN ACCESS INTERNET
1 24 U U U ISP "INTERNET"
IF i do this configuration obove on the GS724tv3 FW 5.4.2.18 Firmware Version 6.0.1.29
no internet on all port . this is the config if i do the same .
5 1 U NO ACCESS INTERNET
5 2 U NO ACCESS INTERNET
5 - U NO ACCESS INTERNET
20 19 U NO ACCESS INTERNET
20 20 U NO ACCESS INTERNET
20 21 U NO ACCESS INTERNET
20 22 U NO ACCESS INTERNET
20 23 U NO ACCESS INTERNET
1 24 U ISP "INTERNET"
i cant configure the vlan 1 always saying " vlan 1 was not created by user"
Please Help thanks in advance.
schumaku
Jul 31, 2020Guru - Experienced User
That much from my side: Multiple [U]ntagged VLAN on the same port is not an appropriate clean 802.1q configuration where each VLAN is it's own dedicated broadcast domain - what this configuration does is so called asymmetrical VLAN config, the support is optional, on truns it's an optional extension protocol. Why ever, all (?) Netgear swiches seem to allow this config in the Web UI, but not all switches are working it accordingly.
I'm trying to talk to Netgear on this subject but no success YeZ - still no communication with the Smart Managed Pro/Plus PLMs and engineering ....
- markii_0204Aug 06, 2020Aspirant
any updates ?
is someone can help me to set vlan on this model that can both vlan have internet access?
1 trunk port to ISP modem then 2 vlan with internet access.
thanks
