sparky2811
Mar 08, 2018Aspirant
Netgear GS748Tv4 Fan Failure - Replace fan or Switch?
Dear all A few days ago I noticed a loud rattling noise coming from our GS748Tv4H1 48 port switch. Logging into the web interface I see that there is a 'fan failure'. I imagine years of dust...
- Apr 01, 2018
I just want to follow-up on this. Were you able to access the links I shared?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Mar 28, 2018NETGEAR Employee Retired
Hi sparky2811,
Let me share these links I found online that might help you with your concerns:
NETGEAR GS748T/GS724T Switch Loud Fan Swap Modification
NETGEAR GS748T Switch Loud Fan Swap with Quiet Fan
NETGEAR GS724T Switch Fan Replacement
Hope it helps! :)
DaneA
DaneA
Apr 01, 2018NETGEAR Employee Retired
DaneA
- sparky2811Apr 01, 2018AspirantHi, thank you for the links. I'll try replacing the fan. Thanks for your help. :)
Mark
