jkalber87
May 19, 2023Tutor
Netgear GS752TPV2 can't access web interface
Hello,
I have a Netgear GS752TPV2 managed switch at one of the offices that I support. The issue I am having is I am unable to reach the web interface for this switch, but I am able to ping the switch and receive a response back. I haven't rebooted the switch yet to see if that'll clear the issue up. Wanted to check here before doing so. I have not made any recent changes to the switch.
edit: left out some important information - when I do try accessing the web interface via IP, I do not receive any error messages or time-out messages. The web browser page just continues to spin and try to load but nothing ever populates.
Bump! Any help here would be greatly appreciated, thanks!
- HannesKannesInitiate
Hi,
The interface can only be accessed from the defined VLAN (by setup). So accessing PC must be inside this VLAN.
Furthermore the basic setting is HTTP to access the side. Please check the correct adress for HTTP and not HTTPS in the browser.
Best regards
Jan
Hello HannesKannes, that worked! When I typed in the IP address of the switch, it automatically threw the HTTPS:// in front of the IP address. I am now able to access the web interface by using HTTP:// instead of HTTPS://
Thanks for your help!
