MK23
Aug 13, 2019Aspirant
Netgear GSM7352s - Image corrupted, auto reboots
Network Switch Model: Netgear GSM7352s v1 Had upgraded my switch to latest firmware 8.0.3.49 and later by mistake tried to upgrade to 10.0.0.53 (which is supposed to be for v2 version) Now my sitch...
DaneA
Aug 20, 2019NETGEAR Employee Retired
MK23,
The only option to recover the GSM7352sv1 switch as well as put a working image back to it is only through Xmodem. If you need the gsm73xxs-6.2.0.6.opr, you may download it here.
Kindly read page 4-9 of the ProSafe 7300 Series CLI reference manual here about the format of the copy command specifying Xmodem.
Hope this helps.
DaneA
NETGEAR Community Team
MK23
Aug 23, 2019Aspirant
When i try to do normal file tranfer, it works fine.
But when i try to transfer file using xmodem protocal it fails after few minutes.
Tried to transfer file via xmodem using hyperterminal, minicom, tera term but same result.
- MK23Aug 23, 2019Aspirant
Not sure if this works or not,
But is it possible to get the Image file for this switch and upload the file (without using xmodem).
I am just not able to tranfer file using xmodem.
Operational Code Date: Thu Mar 19 18:12:33 2015
Uncompressing.....
Adding 0 symbols for standalone.
reg DYNCELLLIMIT field DYNCELLSETLIMIT is invalid
Generating log error crashdump file...
Scanning devshell symbols file...
50491 symbols loaded.
log_error_code reg.c 2277
Boot Code 01.00.35
CPU Card ID: 0x508541Boot Menu 01.00.35
Select an option. If no selection in 3 seconds then
operational code will start.1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):2
Boot Menu 01.00.35Options available
2 - Change baud rate
3 - Retrieve event log using XMODEM
4 - Load new operational code using XMODEM
5 - Load new operational code using USB
6 - Display operational code vital product data
7 - Abort boot code update
8 - Update boot code
9 - Delete operational code
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - File system directory listing
15 - Upload a file through XMODEM
16 - Download a file through XMODEM
[Boot Menu] 2
Select baud rate:
1 - 1200
2 - 2400
3 - 4800
4 - 9600
5 - 19200
6 - 38400
7 - 57600
8 - 115200
0 - no change
-> 8Setting baud rate to 115200, you must change your terminal baud rate.
ýBoot Code 01.00.35
Select (1, 2): 2
[Boot Menu] 4
Ready to receive the file with XMODEM/CRC....
Ready to RECEIVE File xcode.bin in binary mode
Send several Control-X characters to cancel before transfer starts.
CKCKCKCKCK- MK23Aug 26, 2019Aspirant
Using xmodem protocol, file transfer fails after transfering approximately 14k to 15k data.
Is there a way to delete the existing corrupted image in the switch.
- msiAug 26, 2019Luminary
Hi
Have you tried 9 in the menu? ("9 - Delete operational code") - It wouldn't be my first thing to try, at the start, but considering you have tried several things at that point, what are you risking? (On the M4100 a similar option 14 exists: "Reformat the file system")
If all this fails, you might have problems with the integrated flash memory and this could mean that your switch is gone for good.
Your switch doesn't (yet) have a USB port which would be that other method of getting firmware loaded instead of XMODEM. This option was only integrated with later models. You are therefore pretty much stuck to XMODEM at that point. It might be possible there is an internal USB header not exposed externally or a simply a feature not disabled in this boot menu since you can see "5 - Load new operational code using USB" in your boot menu.
