testuser777
Apr 17, 2025Aspirant
netgear m4250 cannot access uboot
The switch boots fine to a login in and everything but I cannot access the uboot command prompt. Usually there is a prompt to press C to access the uboot but instead I get the gibberish below and th...
LaurentMa
Apr 17, 2025NETGEAR Expert
Hi testuser777
Sorry for this issue, may it serve to the rest of the Community - for support requests and troubleshooting, kindly reach out to us sending a message (email) to [email protected] and one System Engineer will come back to you and help you fix it.
Thank you!
testuser777
Ok, will do and I noticed I said I was pressing C but I meant to say spacebar. I'll email them. Thanks for the reply.
