d_nell20
Feb 23, 2021Aspirant
Netgear M4300-28G to Cisco connection
I'm trying to connect my M4300-28G switch back to a Cisco switch that is out of my control. However I have been given the config that should go on the M4300-28g's interface so it can talk back to the Cisco switch, which is :
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 211,691
switchport mode trunk
My current config that is on the M4300-28G
!Current Configuration:
!System Description "M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+, 12.0.7.13, B1.0.0.11"
!System Software Version "12.0.7.13"
!System Up Time "1 days 2 hrs 57 mins 29 secs"
!Additional Packages QOS,Multicast,IPv6,IPv6 Management,Stacking,Routing
!Current SNTP Synchronized Time: SNTP Last Attempt Status Is Not Successful
serviceport protocol none
vlan database
vlan 211,691
vlan routing 1 1
exit
configure
stack
member 1 1
exit
no ip routing
line console
exit
line telnet
exit
line ssh
exit
interface 1/0/1
description 'LN_300_E23'
vlan pvid 691
vlan ingressfilter
vlan participation include 211,691
vlan tagging 211,691
exit
interface vlan 1
routing
ip address dhcp
exit
router rip
exit
router ospf
exit
ipv6 router ospf
exit
exit
The part I'm having trouble with is the "switchport trunk encapsulation dot1q" because I have not been able to get that on the M4300-28g. Which may or may not be the reason it's not connecting back to the Cisco switch. Is there something with that, that I'm missing? Any help with this is greatly appreciated.
Flying over your config it looks like have configued the two VLANs 211 and 691, and the port 1 is configured as a trunk (carrying 802.1q VLAN tags) for the VLAN id 211 and 691.
All the other ports on this switch are either unconfigured or are defaulting to an access port on VLAN 1 so all ports are on a third network, different from VLAN 211 and VLAN 691.
You need to figure out on how the systems you intend to connect are intended to work with these two VLANs, e.g. some ports as access port for VLAN 211, and another set of ports as an untaged access port for the VLAN 691, as trunks again, ...
- d_nell20Aspirant
Ok will try that.Thanks so much. This has been driving me bonkers lol lol lol
