Scriptoe
Aug 03, 2022Aspirant
Netgear M43000 DHCP Server Setup
I need a simple network setup where the I have a single private network of equipment that all need to be assigned an IP. All the equipment is managed from a host PC with with two separate LAN cards...
DaneA
Sep 01, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Let me share the article below and use it as your guide:
Also, I found this old community thread here. Kindly access and read it as it might help you as well.
DaneA
NETGEAR Community Team
Scriptoe
Sep 01, 2022Aspirant
Hi DaneA,
Thanks for the reply. I have gone through the guide you pointed to. I must be doing something fundamentally wrong as I have gone through several configuration and have yet to come up with a working solution.
I do see after enabling the DHCP server on the switch and looking at the DHCP server statistics. The switch in indeed getting IP request from clients (DHCPDISCOVER increments). But the according to the switch DHCP Server Statistics DHCPOFFER no IPs are being sent.
Thanks in advance for the help,
Rick
