rick_h1
Jun 17, 2022Aspirant
netgear poe switch 8 port managed or Unmanaged
I would like to setup easy to maintain PoE 8 port the switch will have three access points and in the next few months two ip cameras. So do not know if it would be best to go with managed or unmanage...
Jun 17, 2022Guru - Experienced User
Are you planning on getting AP's the use central management? Or using vlans or anything else for the switches?
If your new to networking or unexperienced, I usually advise people to keep it simple and stick with unmanaged. .
but if your more experienced or wanting to get into managed switches, then its not a bad idea to try managed.
