adeeb_taqui
Dec 10, 2019Aspirant
Netgear switches compatible with Cisco ISE
Greetings To All, My customer is asking if the their Cisco ISE is compatible with our newly deployed nettgear switches like M4300-96X; XSM4316S / M4300-8X8F;XSM4324S/M4300-12X12F; Do you know of...
- Dec 10, 2019
Hello adeeb_taqui
Thank you for your question. While there is no reference that I can think of, we can expect that Cisco® ISE supports interoperability with any non-Cisco RADIUS client network access device (NAD) that implements common RADIUS behavior for standards-based authentication. Of course, proprietary or specific Cisco TrustSec® or pxGrid wouldn't be supported across the M4300 switches, but again the standard dot1x authentication should work fine, M4300 switches come with a standard and robust Radius implementation (see the Radius RFCs supported page 46 in the M4300 datasheet).
I hope this helps,
LaurentMa
Dec 10, 2019NETGEAR Expert
Hello adeeb_taqui
I hope this helps,
adeeb_taqui
Dec 11, 2019Aspirant
Thankyou.
