jameswiltshire
May 28, 2019Aspirant
Next Hop IP Address Help (M4100-50G)
Hi, I need some help on understanding how the next hop ip address works on mulitple switches. I have; Router on 10.0.0.1 (vlan 10) Netgear switch 1 (10.0.0.2) connected on port 1. vlan 10 set...
schumaku
May 29, 2019Guru - Experienced User
James,
As there is only a single VLAN, it's all plain L2, and no routing involved at all for connections on the VLAN 10. Carefully check the trunk link between the switches (VLAN ID 10 tagged), and the ports (VLAN ID 10 untagged, PVID 10) - that's all.
-Kurt
