tensi0n519's avatar
Oct 01, 2019
Link Aggregation between GSM7224R and M4100-50G-POE+ setup help
I have two switches, M4100-50G-POE+ and GSM7224R . I am trying to set up link aggregation between both of them using the last 4 ethernet ports on each. I'm not exactly sure as to what needs to be set on both of the switches to get this to work.
Thank you.
  • tensi0n519,
    Welcome to the community! :)
    Let me share the article below and use it as your reference guide:
    How to configure LAG between two NETGEAR managed switches?
    If your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    tensi0n519,
    DaneA
    • Thanks for the response and linking the guide. I followed all of the instructions on the guide. The only thing it does not mention is which "Hash Mode" I should use. When I set up the lag per the guide, the switches are unable to talk to each other so I feel like something is still not set up right. The M4100 shows that the LAG is up but I am unable to connect to the GSM7224R switch now. The cat6 cables I'm using are in good order as well.
    • I was able to fix the issue. Turns out it was a firmware issue. Had to update the firmware on both switches and they work as they should now. Thanks again for your help.
      • DaneA's avatar
        DaneA
        tensi0n519,
        You're welcome! :)  I'm glad that you were able to upgrade the firmware of both switches and got it working.
        Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
        DaneA
ProSupport for Business
