jameswiltshire
May 28, 2019Aspirant
Next Hop IP Address Help (M4100-50G)
Hi, I need some help on understanding how the next hop ip address works on mulitple switches. I have; Router on 10.0.0.1 (vlan 10) Netgear switch 1 (10.0.0.2) connected on port 1. vlan 10 set...
jameswiltshire
May 29, 2019Aspirant
Hi,
Thanks for the reply. I think i get vlan routing and next hop now. My problem is i can`t connect to the management page of a phone that is on the second switch when i`m connected to the first switch. I can ping the phone but not connect unless i connect my laptop to the second switch.
Thanks
schumaku
May 29, 2019Guru - Experienced User
All devices play in the 10.0.0.0/24 (255.255.255.0) subnet on this VLAN 10?
Double check the Voice VLAN feature does not play against your intentions, e.g. putting the traffic from a phone into a different VLAN than what you think.
- jameswiltshireMay 29, 2019Aspirant
It looks like i have other issues as on our router i can see unknown network segment for that ip address. I`ll restart our router as i made a few changes recently which may solve my problems.
- schumakuMay 29, 2019Guru - Experienced User
Veto! Neither your router nor the inter VLAN routing is involved for talking on the VLAN ID 10 - which does (or should) represent a flat L2 network, no routing at all - on one or over multiple switches. The unknown network segment is an issue, but not for this connection.
