Onnovh
Jul 22, 2015Aspirant
No Gigabit connection GS108Ev3
Hi, recently I bought a GS108Ev3 to upgrade my GS105E. The problem is that I can't get a Gigabit connection on my laptop (Asus K52JC with JMicron Gigabit Ethernet Adapter incl. latest drivers...
DaneA
Jul 23, 2015NETGEAR Employee Retired
Hi Onnovh,
Kindly answer the questions I have summarized below:
1. Have you tried connecting your Asus laptop to all 8 ports of your GS108Ev3?
2. Do you get 100Mbps of connection on all 8 ports of your GS108Ev3?
3. What port LEDs are lit up when your Asus laptop is connected to any of the 8 ports of your GS108Ev3?
4. What is the current firmware version of your GS108Ev3?
5. Have you tried to reboot your GS108Ev3 while your Asus laptop is connected to it and still get 100Mbps of connection?
6. Have you tried to reset your GS108Ev3 to factory defaults?
I will be looking forward to your response.
DaneA
Netgear Community Team
- OnnovhJul 24, 2015Aspirant
DaneA wrote:1. Have you tried connecting your Asus laptop to all 8 ports of your GS108Ev3?
Yes I dit, all ports give 100mbps.
Yes.
Left LED (100M)
Latest, 2.00.05.
Yes , I did, still 100Mbps.
Yes, I did, still 100Mbps.
I tested all ports with a ReadyNas 102, all 8 ports gave 1Gbps connection.
When I use this setup I get a 1Gbps connection:
Asus <--> GS105E <--> GS108v3 <--> Modem
But with this setup I get a 100Mbps connection no mather what I do:
Asus <--> GS108v3 <--> Modem
Network card is set to Auto negotiation, Forcing 1Gbps doesn't do anything.
It's really frustrating because I really need those 3 extra ports!
- JennCJul 24, 2015NETGEAR Employee Retired
Hello Onnovh,
Is it GS108v3 or GS108Ev3? They are not the same. The GS108v3 is just a pass through switch while the GS108Ev3 is a Prosafe Plus switch that has FW.
If you are using GS108Ev3, try updating the firmware. See GS108Ev3 downloads
Also with this setup Asus <--> GS105E <--> GS108v3 <--> Modem, leaving both switches connected to each other and you connect computer straight to the GS108, do you still get gigabit speed or the 100mbps?
We sincerely apologize for any inconvenience this may have caused and look forward to your update.
Hi JennC
I'm sorry for the confusion.
I have a Netgear GS108Ev3 with 2.00.05 firmware.
When I keep both switches connected and I plug my laptop in de GS108E I still get 100Mbps.
- Apr 12, 2023Retired_Member
