zx10guy
Jul 18, 2017Aspirant
Out of band port on M4300-8x8f
A bit new to Netgear fully managed L3 switches but not new to managed switches in general. As the subject reads, I just purchased a M4300-8x8f. I configured the out of band management port and am a...
Retired_Member
Jul 18, 2017Hi zx10guy
Welcome to the community!
Could you please provide more detailed info as below:
1. Is SNTP Server and out of band port IP address in same subnet?
2. Do you set IP for VLAN1?
3. Do you set default-gateway for VLAN1? Or does VLAN1 get IP and Gateway from DHCP?
By default VLAN1 is worked as Management VLAN, if set IP for VLAN1 and set default gateway for Switch, it will generate one default route with nexthop point to gateway.
In your scenario, you want use out of band for management and control plane service.
So I suggest you disable vlan routing for VLAN1.
And then try again.
Hope it helps!
EricZ
NETGEAR employee
zx10guy
EricZ,
Thank you for replying. The NTP server I'm trying to reach is a NIST NTP server on the internet. I have quite a few of my network attached hardware pointing to the same server for clock syncs. I did not configure anything for VLAN1. It's set for DHCP so there is no IP settings assigned to the virtual interface. I have also disabled routing for VLAN1 thinking that may be the issue and I still can't reach the NTP server via the out of band port. It just seems I'm being forced to use a virtual interface on any VLAN for management traffic even though there is an out of band management port available.
If I have to use a virtual interface for SNTP, SNMP, etc for management traffic, I will. It's just a shame I can't just do all of that off of the out of band port.
