robfantini
May 11, 2017Aspirant
pfsense lag
Hello I've got LAG working for our 11 linux machines. I am having trouble getting pfsense [ uses freebsd ] lagg working. I've tried 3 diff has modes - 3- src/dest mac.. , 6- src/des...
- May 13, 2017
OK the solution for us was to use teo of the same model nic.
Use em0 and em1 nics instead of two different models [ re1 and em0 ]. I assume re0 and re1 would work.
And the information posted by LaurentMa is exactally how to configure pfsense lagg to work with our netgear switch.
robfantini
May 13, 2017Aspirant
Hello
thank you for the reply. It is good to know that this can work.
I had already tried exactally as you suggested.
We may have a hardware issue - the nic on pfsense I suspect driver issue. I'll try using a test system with a different nic .
I'll be back.
robfantini
- robfantiniMay 13, 2017Aspirant
I tried to edit this line to fix a typo , but could not see how to make the change. so:
This
Shoud be:
OK the solution for us was to use the same model nic.
