robfantini
May 11, 2017Aspirant
pfsense lag
Hello I've got LAG working for our 11 linux machines. I am having trouble getting pfsense [ uses freebsd ] lagg working. I've tried 3 diff has modes - 3- src/dest mac.. , 6- src/des...
- May 13, 2017
OK the solution for us was to use teo of the same model nic.
Use em0 and em1 nics instead of two different models [ re1 and em0 ]. I assume re0 and re1 would work.
And the information posted by LaurentMa is exactally how to configure pfsense lagg to work with our netgear switch.
LaurentMa
May 14, 2017NETGEAR Expert
M5300, M7100 and M7300 series are more than ideal too, running 11.0, 10.0 or 9.0 previous Fully Managed codes from NETGEAR. Vast majority of software feature set is the same, including granular hashing for best LAG / LACP interop.
I mentioned latest managed switch series in my previous post, as above series were gradually replaced by newer M4300 series. Again, you have excellent platform with M5300.
Managed Switch portfolio is visible here: www.netgear.com/managed
