VanGochAudio
Jan 27, 2026Aspirant
PoE issue with low power device (DOREMiDi MR-1 PoE) on Netgear M4250 switch
Hello, I am experiencing an issue with PoE when using a Netgear M4250-9G1F-PoE+ switch together with a low power PoE device. Setup: Switch: Netgear M4250-9G1F-PoE+ Device: DOREMiDi MR-1 Po...
VanGochAudio
Feb 02, 2026Aspirant
Hello shumaku,
Thank you for your post and for taking the time to share your insights.
From a physical observation perspective, the behavior is very clear:
- The LEDs on the DOREMiDi MR-1 PoE pulse repeatedly
- The device appears to start up briefly
- After a short time, it powers down again
- This cycle repeats continuously
This strongly suggests that PoE power is being applied and then withdrawn by the switch.
Regarding power consumption:
The manufacturer of the DOREMiDi MR-1 PoE has confirmed the following:
“This issue may be due to the low power consumption of the MR-1 PoE. Some PoE switches continuously cycle between powering on and off because the powered devices consume low power.”
The MR-1 PoE has an approximate power draw of ~1.5W, which appears to be below the effective sustain threshold used by the Netgear PoE controller. While I fully agree that, per IEEE 802.3af specifications, a Class 0 or Class 1 PD should be supported within the defined power range, the real-world behavior on this switch indicates that PoE power is being removed after initial negotiation.
As mentioned earlier, the same device operates continuously and reliably on a Cisco LGS108P, which suggests a difference in PoE power sustain or detection behavior rather than standards compliance of the PD itself.
To further investigate this, I have now opened a support case with Netgear and have provided logs extracted directly from the switch to assist with the analysis.
Thanks again for your input — it is very much appreciated.
schumaku
Feb 03, 2026Guru - Experienced User
VanGochAudio wrote:The manufacturer of the DOREMiDi MR-1 PoE has confirmed the following:
As this MR-1 is a very nice product: If you have contact to them, please let them know that you suggest a more complete PoE description, the "To power the product through the network port, please make sure your router/switch has PoE function" is extremely unclear, we suggest something like this instead:
Power over Ethernet: PoE Standard (IEEE 802.3af), backwards compatible to PoE+ (IEEE 802.3at) and PoE++ (IEEE 802.3bt) PSE (Power Source Equipment). Notes: a) Contact the PSE (PoE router, switch, injector) manufacturer if you find the DOREMiDi MR-1 PoE in an unexpected power loop, caused by the low power consumption of just ~1.5W b) Proprietary passive (eg. 24V or 48V) non-IEEE compliant PoE systems are not supported.
