ebikeeric
Jan 29, 2024Aspirant
Port Rate Control in Kbps
I am trying to create a test environment where I can reduce port speeds to really low data rates. Preferably as slow as 1 Kbps but 10 Kbps would be suitable. Yes, I said "Kbps" not Mbps...this is I...
schumaku
Jan 31, 2024Guru - Experienced User
Consider implementing a software bridge, e.g based on iptables, where you can netem and the like:
tc qdisc add dev eth0 root netem rate 56kbit
No way on a real-world low-cost switch, which requires have different capabilities.
ebikeeric
Jan 31, 2024Aspirant
Thanks for taking the time to respond. It appears Netgear does not allow for this capability without complex command line activity and software - which is not something I can do for this.
- schumakuJan 31, 2024Guru - Experienced User
Not talking of any physical Netgear (or other brand) switch - much more, I have a small Linux system in mind 8-)
Rate limits on physical switches massively depend on the hardware capabilities. Typically, one can set % numbers, typically in steps of about 5%. Background: Switches are made for fast frame forwarding, not for laboratory type applications - counting frames is a switch competency, not throttling the way you expect.
