ptoschi
Mar 23, 2018Aspirant
Problems with LAG von M4300-8x8F switches
Hello, we have 4 M4300-8x8 Switches in two server rooms. In both rooms there are 2 Switches stacked together. These two stacks are connected by LAG (one cable per switch). Originally the LAG consist...
- Mar 27, 2018
Hello,
thank you for the reply. I only tried Hash mode 7 after I encountered the problems. But I will of course set it back to 3.
I will try to reboot the switches on the weekend. Then I will be able to use the new firmware and the lag will probably work anyway.
Thank you for your help!
Retired_Member
Mar 26, 2018Hi ptoschi,
Welcome to the community!
First, you need add all ports as LAG members on Switch, include fiber port and copper port. And the up ports member will change to active port, and will forwarding traffic. And other config for LAG just keep default.
So please run CLI commad as below to check LAG members:
'show port-channel 1'
Hope it helps!
EricZ
NETGEAR employee
ptoschi
Mar 26, 2018Aspirant
Hello,
the 4 ports in question are all members of the lag group:
| 1/0/1, 1/0/9, 2/0/1, 2/0/9 | 1/0/9 |
The problem is, if i connect more than one port on the fly, I get connection errors. It worked fine in the beginning so I suspect it would work again if i gut shut down the switches, connect the lag ports and then start up the switches again. Unfortunately that is not possible at the moment and I would expect the lag group to accept changes on the fly.
By the way, the CLI command did not work (it would not accept the "1" after the command, but I can see everything in the web interface.
Thank You,
Peter
- Retired_MemberMar 26, 2018
Hi ptoschi,
For further analysis, Could you please provide the tech-support file of the Switch? Include two stacking switches.
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439- ptoschiMar 26, 2018Aspirant
Thank You very much for your help. I've sent the files to [email protected]
Hi ptoschi,
Thanks for immediately response!
Yes, it's enough.
And I notice some ports are blocking by STP protocol. So please run below CLI command to check STP status(plug-in all LAG member ports, include copper and fiber port):
1. show spanning-tree summary
2. show spanning-tree mst port summary 0 active
3. show port-channel 1 (you mean this command cannot be executed on console port?)
Besides: The firmware is too old on your 4 switches, could you please upgrade to latest image and try again?
The latest firmware link is image
