ptoschi
Mar 23, 2018Aspirant
Problems with LAG von M4300-8x8F switches
Hello, we have 4 M4300-8x8 Switches in two server rooms. In both rooms there are 2 Switches stacked together. These two stacks are connected by LAG (one cable per switch). Originally the LAG consist...
- Mar 27, 2018
Hello,
thank you for the reply. I only tried Hash mode 7 after I encountered the problems. But I will of course set it back to 3.
I will try to reboot the switches on the weekend. Then I will be able to use the new firmware and the lag will probably work anyway.
Thank you for your help!
Retired_Member
Mar 26, 2018Hi ptoschi,
I notice the LAG1 Hash Mode is 7 on your Switch. Unfortunately the switch M4300-8X8F not support this Mode right now, it's a known problem, limited by Hardware. So suggest change to other Hash Mode(1-6, default is 3) and try again.
Hope it helps!
ptoschi
Mar 27, 2018Aspirant
Hello,
