Muzzzzy
Sep 16, 2018Aspirant
Prosafe GS108Ev3 with a TPLink AV600
Hi,
I have recently purchased a managed switch GS108Ev3 and having a strange issue with what almost appears to be a DOS attack.
If i connect my wired lan devices then all appears to be ok however...
schumaku
Sep 16, 2018Guru - Experienced User
Does connecting the TPLink AV600 establish a network loop - because of the new GS108Ev3 is connected to the router and the PC, and the AV600 does also create a link to the very same router?
- MuzzzzySep 17, 2018Aspirant
I am not quite sure of what you are asking. The setup up is my router is connected to the Gs108Ev3. My pc and two AV600`s are then connected to the GS108Ev3. The two AV600`s are used to supply internet to a couple of locations elsewhere in the house where i am unable to cable. ¬The AV600 appear to connect ok to the paired units however i have been more focused on what has been happening with my pc so never tested if they are working.
- Apr 12, 2023Retired_Member
