FSIT
Jul 19, 2011Aspirant
Prosafe GSM7248 LAGs & LACP
I'm looking into purchasing a pair of Prosafe GSM7248 switches 2nd hand and was wondering if anyone knew how many LAGs were supported, and if the switch supports LACP. I looked through a manual that I...
ZCPM3
Aug 12, 2011Aspirant
FSIT wrote: Now... How do we reset the password on these things? Tried the defaults and they don't work. Tried "Erase current configuration" and even made the mistake of "Erase permanent storage" and still unable to log in (even after flashing new firmware after the previous mistake).
The "EmergencyPasswordRecovery" trick doesn't work.
FSIT, can you walk me through how you got your switch back up and operational? I just made the same mistakes you did and my console is all messed up now. :(
