FSIT
Jul 19, 2011Aspirant
Prosafe GSM7248 LAGs & LACP
I'm looking into purchasing a pair of Prosafe GSM7248 switches 2nd hand and was wondering if anyone knew how many LAGs were supported, and if the switch supports LACP. I looked through a manual that I...
ZCPM3
Aug 12, 2011Aspirant
FSIT wrote: I would, but it requires re-flashing the newest firmware to the switches. Unfortunately there's a problem with the newest firmware, where it WIPES the switches MAC addresses! So now I can access both switches, but they don't work correctly and you can't have more than one on the network at a time (because it defaults to the firmwares IP of 00:00:01:02:03)!
I have a support ticket open with Netgear now, they're working on fixing this problem, but for now I'm using a GSM7224 and four "dumb" switches just so our network kinda works.
Well I can't even get to the admin menu in the console so you're further along than me. I may just open up an RMA request and put that lifetime warranty to work!
