FSIT
Jul 19, 2011Aspirant
Prosafe GSM7248 LAGs & LACP
I'm looking into purchasing a pair of Prosafe GSM7248 switches 2nd hand and was wondering if anyone knew how many LAGs were supported, and if the switch supports LACP. I looked through a manual that I...
Glitched
Aug 26, 2011Aspirant
As long as you have a purchase date past May 1st, 2007 then all prosafe products have a lifetime warranty. If the support site is showing the warranty expired then its just a glitch or bug in the interface.
When you cleared the permanent storage, you didn't only erase the firmware, but all vital product data. The problem you're experiencing with the MAC address being wiped out wasn't done by the firmware.(I have several of these switches updated weekly and don't have the MAC wiped out).
Best thing to do is to open a support case at my.netgear.com and see if engineering can do anything or if they will issue an RMA.
Also what password are you trying? The default password for these switches are blank.
