Secretdook
Jul 02, 2015Aspirant
ProSafe GSM7328Sv2 not booting
Hi all. So I've had a GSM7328Sv2 for a while now and kinda run into an issue with the switch itself. I recently replaced my router that uses a different LAN range and I've not been able to acce...
Secretdook
Sasword wrote: Have you tried to reboot your GSM7328Sv2 by unplugging its power cable from the power outlet then re-plug it again?
I have yes, hasn't cleared the error.
