Secretdook
Jul 02, 2015Aspirant
ProSafe GSM7328Sv2 not booting
Hi all. So I've had a GSM7328Sv2 for a while now and kinda run into an issue with the switch itself. I recently replaced my router that uses a different LAN range and I've not been able to acce...
RX
Jul 02, 2015Luminary
It seems that your GSM7328Sv2 turns out to be faulty. I suggest that you should contact Netgear Support and check if your GSM7328Sv2 is still valid for a replacement: http://support.netgear.com/general/contact/#tab-call
