Secretdook
Jul 02, 2015Aspirant
ProSafe GSM7328Sv2 not booting
Hi all. So I've had a GSM7328Sv2 for a while now and kinda run into an issue with the switch itself. I recently replaced my router that uses a different LAN range and I've not been able to acce...
Nhellie
Jul 17, 2015Virtuoso
Try resetting the switch using the sequence below:
Note: You'll be pressing the Factory default button for a total of 90 seconds.
1. While the switch is on (powered), push and hold the Factory default button for 30 seconds.
2. Turn off the switch, continue to hold the Factory default button for another 30 seconds.
3. Turn on the switch, still holding the Factory default button do this for 30 seconds more.
4. Release the Factory default button, let the switch boot by itself.
5. After about 2-5 minutes, see if you can access the switches interface.
