technotechnotec
Apr 04, 2018Guide
ProSafe M4300 sending double RADIUS access-requests
Hi all, I'm setting up RADIUS/AAA using Windows NPS to authenticate users against a domain group, and I'm seeing a weird issue - it's working, but it's crufty. I'm on version 12.0.2.6 if that has...
DaneA
Apr 10, 2018NETGEAR Employee Retired
Hi technotechnotec,
As far as I have checked, there is no issue logged on the M4300 switch series as per described in your post. Since the current firmware of your M4300 switch is old, I suggest you to update it to the latest version which is 12.0.4.8 in order to isolate the problem. You can download firmware v12.0.4.8 here.
Be reminded to perform a factory reset after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, check if you will encounter the same problem.
DaneA
NETGEAR Community Team
technotechnotec
Apr 11, 2018Guide
Thanks Dane, this has been added to my to do list.
I'll update if the firmware update fixes the problem.
Thanks!
