tantony's avatar
tantony
Luminary
Feb 06, 2019
ProSAFE XS728T, DHCP on trunk port?
Is it possible to do DHCP on trunk ports?   On my Netgear switch, I have VLANs 128 and 192.  I've made port 23 and 24 trunk ports.  I'm connecting an access poing to the trunk ports because the S...
  • schumaku's avatar
    schumaku
    Feb 06, 2019
    tantony wrote:
    The AP is connected to trunk port 24, and I tagged it with VLANS 128 and 192 because the AP SSIDs are using those VLANS.  The port PVID is 1.  So if I change the port PVID to 128, the AP will get DHCP from that VLAN?
    Yes, untagged traffic will be associated to the VLAN 128 then.
    tantony wrote:
    I'm assuming the SSIDs will still work?
    Of corse, yes. Not sure why you intend to expose the management VLAN to the wireless, up to you...
    tantony wrote:
    The AP is connected to trunk port 24, and I tagged it with VLANS 128 and 192 because the AP SSIDs are using those VLANS.  The port PVID is 1.  So if I change the port PVID to 128, the AP will get DHCP from that VLAN?  I'm assuming the SSIDs will still work?
    I guess it makes sense why the AP is not getting a dhcp now because the PVID is 1 no ports are members of VLAN 1.
    Yep - no DHCP server on the VLAN, too.
ProSupport for Business
