tantony
Feb 06, 2019Luminary
ProSAFE XS728T, DHCP on trunk port?
Is it possible to do DHCP on trunk ports?
On my Netgear switch, I have VLANs 128 and 192. I've made port 23 and 24 trunk ports. I'm connecting an access poing to the trunk ports because the S...
- Feb 06, 2019
tantony wrote:
The AP is connected to trunk port 24, and I tagged it with VLANS 128 and 192 because the AP SSIDs are using those VLANS. The port PVID is 1. So if I change the port PVID to 128, the AP will get DHCP from that VLAN?
Yes, untagged traffic will be associated to the VLAN 128 then.
tantony wrote:
I'm assuming the SSIDs will still work?
Of corse, yes. Not sure why you intend to expose the management VLAN to the wireless, up to you...
tantony wrote:
The AP is connected to trunk port 24, and I tagged it with VLANS 128 and 192 because the AP SSIDs are using those VLANS. The port PVID is 1. So if I change the port PVID to 128, the AP will get DHCP from that VLAN? I'm assuming the SSIDs will still work?
I guess it makes sense why the AP is not getting a dhcp now because the PVID is 1 no ports are members of VLAN 1.
Yep - no DHCP server on the VLAN, too.
tantony
schumaku
Feb 06, 2019Guru - Experienced User
- tantonyFeb 06, 2019Luminary
Thanks, learned something new today. I'll try that tomorrow and update.
- tantonyFeb 06, 2019LuminaryI restarted the switch before I left for the day, but looks like the AP didn’t get a VLAN 128 dhcp. I may need to restart the AP so it will get a dhcp.
- schumakuFeb 07, 2019Guru - Experienced User
tantony wrote:
I restarted the switch before I left for the day, but looks like the AP didn’t get a VLAN 128 dhcp. I may need to restart the AP so it will get a dhcp.Strange, I would expect that this would disconnect and reconnect the Ethernet link, leading to a new bootp/dhcp process.
However, many systems fall back to a default IP or a zero config IP address if the dhcpd does not succeed after a few attempts, e.g. for troubleshooting, initial configuration, whatever. Whats the point for not rebooting the AP? An UniFi AP is unlikley workable and configured without the connection to the UniFi Controller (regardless if it's a CloudKey, installed on a local system, or on a cloud service).
