tantony
Feb 06, 2019Luminary
ProSAFE XS728T, DHCP on trunk port?
Is it possible to do DHCP on trunk ports?
On my Netgear switch, I have VLANs 128 and 192. I've made port 23 and 24 trunk ports. I'm connecting an access poing to the trunk ports because the S...
- Feb 06, 2019
tantony wrote:
The AP is connected to trunk port 24, and I tagged it with VLANS 128 and 192 because the AP SSIDs are using those VLANS. The port PVID is 1. So if I change the port PVID to 128, the AP will get DHCP from that VLAN?
Yes, untagged traffic will be associated to the VLAN 128 then.
tantony wrote:
I'm assuming the SSIDs will still work?
Of corse, yes. Not sure why you intend to expose the management VLAN to the wireless, up to you...
tantony wrote:
The AP is connected to trunk port 24, and I tagged it with VLANS 128 and 192 because the AP SSIDs are using those VLANS. The port PVID is 1. So if I change the port PVID to 128, the AP will get DHCP from that VLAN? I'm assuming the SSIDs will still work?
I guess it makes sense why the AP is not getting a dhcp now because the PVID is 1 no ports are members of VLAN 1.
Yep - no DHCP server on the VLAN, too.
Nodism1125
Feb 07, 2019NETGEAR Expert
Check the Ubiquity AP AC PRO Admin Configuration Page.
Settings > Wireless Networks
Advanced
• VLAN To use a VLAN, select Use VLAN ID and enter the
port number.
schumaku
Feb 07, 2019Guru - Experienced User
Still convinced the UniFi management network has to be run untagged, the UniFi AP don't have an option to configure a VLAN ID for the management.
