acte28
Sep 26, 2021Aspirant
rack or rail kit for m4300-96x
Hello, I'm searching for a rack or rail mouning kit for a M4300-96X switch. One was not included and I am unable to find a part number or vendor selling a kit for this particular model. Has a...
schumaku
Sep 26, 2021Guru - Experienced User
In my understanding, the M4300-96X package does include the front rack mount brackets and the back rackmount brackets with the support rails.
Talk to your reseller, or send an email to customer.support@netgear.com
- acte28Sep 26, 2021Aspirant
Thanks for your reply - agreed. We've bought two of these switches and neither has included rails or a mount kit. The installtion manual indicates that mounting them is possible, but does not include any part numbers or kits that must be purchased separately.
- schumakuSep 27, 2021Guru - Experienced User
Be aware these rails are not slide-out rails - just support to a middle or rear 19" mount.
LaurentMa Is the assumption correct the rack mount kits is coming with the M4300-96X?
- acte28Sep 27, 2021Aspirant
The two switches were bought aftermarket/refurbished. It's entirely possible that initially they included the rack mounts, but when we bought them they were no longer there. There must be an equivalent part that can be used however.
