pbrady's avatar
pbrady
Creating a Routing Interface
Hi there,   I am trying to create a new vlan with routing enabled on my Netgear M5300-28G3. I have created the VLAN no problems, assigned some ports and PVIDs, I can see MACs coming through for the...
  • pbrady's avatar
    pbrady
    Nov 16, 2020
    Hi Retired_Member,
    Sorry for thge slow response. I actually ended up resolving the issue although not in the ideal way. I was trying to create a VLAN for the 192.168.155.0/24 subnet, and this would not work. However I followed the exact same steps for the network 192.168.170.0/24 and it worked, so I'm happy with things for the moment.
    Thanks!
ProSupport for Business
