dialsc
Nov 17, 2019Guide
IGMP Querier behavior on Mgmt VLAN
Hello I am facing a behavior in the area of IGMP snooping/querier which I do not understand and therefore would be thankfull for help. I've got the following setup: Core Switches: - 2 in...
LaurentMa
Nov 23, 2019NETGEAR Expert
Hi,
Please could you paste your configuration file (show run or download HTTP startup config) here so that the Community can look at it?
Alternatively can you export the tech support file and use a file transfer system to send it to me (you can use MP)
Many thanks
Many thanks
dialsc
Nov 23, 2019Guide
Dear Laurent
Thank you very much for taking care about me... ;)
I will put together a ZIP file with the support file of all switches and let you know the download link via PM.
Best
dialsc
