muzicman82
Jun 23, 2020Aspirant
M4200 -> M4300 Multicast Configuration (for NDI / Dante)
Hi all, I am not having any problems currently, but I wanted to run the config by this group and see if there's anything I'm missing or if any tweaks are in order... I have a M4200 with sever...
muzicman82
Jul 13, 2020Aspirant
Thanks. I've gone through the NDI Network Guidelines...
On Flow Control and changing frame size, should I change for all ports including the 10Gig trunk port connecting the two switches? QoS is configured for Dante, which is VLAN2, and I believe those settings apply to all VLANs?
Is setting the frame size to 1518 effectively disabling Jumbo Frames?
I will work to get switch configs posted when I can get into the site.
NeilS
Jul 14, 2020NETGEAR Expert
It should be fine to just change the frame size for the ports to which NDI devices are connected and not necessary to change on the uplink.
Once the default frame size of 9198 for jumbo frames is reconfigured for 1518 on a particular port where an NDI device is connected, this will disable jumbo frames for that port.
Only Dante devices should utilise the specific IP DSCP queue.
If any further issues, please also test the NDI devices when connected to the M4300 (if possible).
This would help with elimination.
Once the changes are made, please confirm the status and send the Tech Support file.
